Got my Duck last Friday. All is going very well. Love the way the curves on the boat develop as you stich it together.
I am however strugling with getting a good fit of the transom piece. All the curves make it very hard to get the transon flush to the other panels.
Any tricks??
I am just completing a WD12 and I also had some problems with the transom. I just used some big spring clamps and drill more holes for wire stitching. Now that I am on my second coat of varnish, the extra holes are long gone under epoxy and varnish.
The transom piece is a common source of challenge/frustration with the WDs. I know I drilled extra holes for more wire, used hot water & rags, and even screwed in temporary pieces of wood across the inside to hold it together. I did/undid it several times, over several days. There should be several posts about this topic in the archives- try searching for WD and see what comes up.
Laszlo may also have something on this building blog http://www.morocz.com/BoatBuilding/DuckBuild.htm
Good luck, Ralph
