Adventures in doing wrong, Southeaster Dory
Picked up a Southwester Dory kit. Have gotten to the point of hull and frames stitched together and flipped the thing over.
What a beautiful looking hull!
At this point I’m wondering, what methods are people using to check for twist in the hull?
Can’t trust my eyes like I used to. Used a level and checked that I’ve got consistent readings across multiple points fore and aft on the bottom and the 2x that make up the tops of the two saw horses it rests on are consistent as well.
Good enough? Something else I should be doing before tacking it together?
Other concern is that it seems to pinch in at the transom. Checked along the sheer strakes with a straight edge and the curve does become concave just before meeting the transom. Played around with different tensions on the wire to no avail. Thinking I might just clamp a board to hold them out a bit until epoxied in place?
Any advice on the above would be appreciated.
The doing it wrong part? At first was considering finishing it out like a larger NE Dory with some additional floatation. After getting a real sense of the size and layout of things, thinking I’ll be keeping some aspects of the SW tanks and seating while changing some others. Time will tell if this is a bad idea or not.
Oar and sail only, no motor.
Some pics:
Won’t soon forget the look on my wife’s face when she poked her head around the basement stairs to ask what all the noise was about as I was just finished knocking the last stud out to open that wall up.
Hard to tell trueness from photos, that pinched look evens out with the outwales.
Ah, hadn’t considered that. Thanks!
