Hi Kidzilla,
while i have not worked on this specific design, i have built and repaired similar centerboard designs. fortunately, its generally eaiser to repair these then repairing the same problem on a production boat.
a good repair works from the outside in…or at least recognizes that the leak has an exposure to the outside that is not evident in your picture.
so i woulld look to find/isolate where that is for a start as that has to be part of the repair process.
from what i see your fillet has delaminated, at least partially, from the cockpit floor. so if it were me, i would begin with a grinding tool or a chisel to remove all of the fillet that had broken away. you might also be able to saw it out carefully with a flexible metal saw blade.
after you remove it you should also be able to find the how the water is actually getting underneath it if its not already obvious. the crack at some point must lead to the box inner surface or the intersection of the outside of the box and the hull bottom.
this crack where the water is actually entering should be filled with lightly thickened epoxy (i would use cabosil for the thickner) that can fill that crack and you need to use care to ensure that in that process of pushing epoxy into that crack/void, that you know where it is going so you don’t accidentally block your box with epoxy or get epoxy somewhere you didn’t want it. depending on what you find after inspecting the outer hull/box junction or the inside of the box, there may be some glass work called for. so if you want to send a picture of what you see, happy to make a suggestion on that element of the repair. strappinng or duct tape is useful in this phase where you are forcing epoxy into a crack but need to stop up the other side to prevent it from just going all over the place or pouring out and not filling the crack.
once you do that, you can then rebuild the fillet with epoxy wood flour. make sure to rough up the area with 60 or 80 git to get a good bond. i also strengthen fillets that are in high stress area with a layer or two of glass over the fillet and approximately two inches upward and ~ 3 inches outward (on the cockpit floor)of the fillet line.
you can do that by sanding the top of the fillets and surround areas with 80 grit and laying the glass in.
inevitably, while this makes it strong, riding a boat with a daggerboard down into a beach may require a re-repair. that’s just a lot of force. but the glass reinforced box/hull connection should be quite reilable for normal wear and tear.
the picture below shows what i mean by glass reinforcement, which unfortunately is not easily visible in the picture, but is the yellow area inside my squiggly red lines up the side of the box and along the floor of the cockpit. this happens to be a skeg box but a dagger board box uses the same priciples…the scale is just larger. this particular box is not going anywhere unless a larger part of the kayak is ripped off
so just a reminder of the key thought on this. you still have to address/block/fill with epoxy the outer entry point through to the inside of the fillet for a complete repair. putting a fillet over an open crack to the water from the inside of the boat will not hold up well in the long run.
