I am not sure if this is actually a bubble. I noticed it when I was adding resin and compressed it down using the squeegee. It is flat and doesn’t bulge. Is it going to be a problem going forward. It is on the side abutting the bottom.
it won’t be a problem. sometimes the weave in the glass gets pushed around…and you will see something like this.
as long as there is not a bubble beneath it just keep going and you won’t see it after the weave is filled and sanded smooth.
Howard,
Yes, the weave is spread out. It may have been there before I started. Thanks.
Rob
