I am currently building a Chesapeake 17LT and I am tossing around a couple of ideas for attaching the foot braces without drilling through the hull. One idea I am considering is to epoxy a 3/8” thick western cedar strip to the inside of the hull and screw the foot brace to the cedar strip with a 1 ¼ “ bronze screws. Are there any other recommended methods?
JM,
Yes, CLC sells a kit for installing your braces without drilling holes in the boat. You glass/epoxy four threaded studs to the inside hull, then bolt your braces to that.
I doubled up on the glass coverage just to feel safe, but they worked great! And the worst thing I think you can do to one of these beautiful boats is have screw-heads showing on the bright sides.
Only caution I'd give on this kit is to use very thick epoxy to set the studs; any runiness and they'll tend to slide down the side of the hull before they cure.
Here's the link to their "Foot Brace Mounting Kit:"
http://www.clcboats.com/shop/products/boat-gear/kayak-footbraces-rudders/internal-footbrace-mounting-kit.html
Good luck,
Larry
