i knocked the boom for my passagemaker off the stand i was using to varnish it, and cracked the end. i put the screw in to turn it like a corn cob but it landed on the screw when it fell and the leverage cracked it. i put the screw back in because it opened up the crack enough so you can see it. the piece was coated with epoxy prior to the three or so coats of varnish i put on, and will now probably be removing. it’s still solidly attached, i’d have to break it off entirely to be able to completely coat it with epoxy, which i don’t want to do. anyway, i don’t know.
what should i do to fix it? thanks in advance!
