After I finished my Chesapeake I took what I learned and restored an old beat up kayak. I really like the boat but it does not track well. I want to install a retractable skeg which means I need to cut a hole in the bottom, it will be about one half inch wide and 15 inches long. I have done a lot of planning and know how I will do this BUT!! My question, what is the best way to cut through the hull of a fiberglass boat. I plan to cut the hole small and use a file to expand it to the proper size (I want a tight fit). Having never done anything like this before, I have come up with two methods, start with a very small drill bit and drill holes along a 15 inch line (allowing for the final bit radius). Keep making the holes bigger until I get the desired width and file it to fit. OR, drill two small holes (planning for the outer diameter to eventually reach 15 inches) expand the holes then connect them with a very fine tooth blade on my sabre saw. File the hole to fit. I plan to ‘install’ the skeg on a piece of plywood before I start cutting into the boat. I am open to other suggestions on how to cut this hole. If you are interested this is the skeg kit.
i just finished a similar skeg installation (different skeg) but almost the same dimensions.
i have done this a couple times and the technique i use is this:
on the outside of the boat i use blue tape to clearly mark the end result of the skeg cutout i am trying to acheive.
so this would be a rectangle 1/2 inch by 15 inches. i would drill two 1/2 inch holes on either side and carefully, slowly cut with a fine handsaw my line between the two holes....using the blue tape as my guide. you can use a jig saw....but i find a fine bladed hand saw gives me more control and less chance of a bad error happening.
if you want to finish it with a file to ensure you leave a bit of space, you can drill15/32 hole and move your tape in 1/64 from each side. and then file out to your final opening. the only other thing i would point out is to make sure if you want only a 15 inch opening, your 1/2 inch hole on each side actually needs to be inset 1/4 inch from each end (so that the hole when drilled will touch the end with the appropriate length.
make sure to wear a dust mask and gloves when doing this work....fibreglass dust is kind of nasty.
i hope this helps.....not a big deal to do this...but you are right to sort it out and get it right....hard to fill an improperly made hole.
I have installed skegs in three boats, using the technique outlined by hspira. Using the 1/2" drill bits at both the forward and aft end of the slot will result in a nice radiused look at both ends. Since large diameter drill bits can walk a bit when they first dig in, I use a small bit to drill a pilot hole then drill with progressively larger bits until reaching the final diameter.
I also prefer a hand saw for this delicate work. It is too easy to make a large mistake quickly with a power saw.
From the link that you posted, it appears that you are installing the KayakSport skeg kit with flange. That kit will work well is the bottom of the kayak is flat. If not you may want to go with the kit without flange. That is what I used on two of my boats.
Hspira and MarkN, thank you both for your help. I like the handsaw idea. The only access I have to the interior of the kayak is through the cockpit and aft access is very limited. I have a closed cell foam block fiberglassed in just behind the cockpit. I put it in after I cut the fiberglass seat out (I did not like the integrated seat). I will not be able to fiberglass the skeg sleeve on the inside so I thougth the flange would add structural integrity to the installed kit. The bottom of the kayak is pretty flat. The flange actually angles up slightly (a small surprise when the kit arrived) so I will use thickened epoxy to fill that gap and glue it in place. I will taper thickend epoxy in front of and behind the slightly raised insert. It will be difficult but I believe I will be able to position predrilled pieces of wood inside the kayak. These will be at either end of the sleeve and screws through the flange (the kit has predrilled holes fore and aft on the flange) will hold them in place. I plan to cut 'U' chanels in the wood, the 'U' will face inward and line up with the hole I cut in the boat so when I slide the insert in it will slide into the fore and aft 'U' slots. This will add strength to the skeg sleeve. I have figured out how to glue these wood pieces in before I tighten the screws. All of this will be done on a plywood mockup before I cut into the boat. Thanks again, I plan to start the first or second week in December. I will let you know how it goes, I will move slowly. Mike
Rather than all the hastle of working through the cockpit, I'd add an aft hatch. This will give you access to install the skeg and when you are done will add storage capability. If the aft deck is relatively flat, I would go with the oval Sea-Lect hatches that CLC sells. That is the hatch in my picture above that was standard with the PP kit.
