decorative fabric question
after applying epoxy to my fabric ca i let it dry before fiberglassing?
I would not, the surface needs to be smooth so no bubbles are under the fiberglass. Also by placing the glass while the eppxy is still wet on the decorative fabric you get a better bond to the wood underneath.
There are some earlier posts. Do it wet. You may need to push it all 'back down' as it drys. It's really quite easy.
Lew
