Dented Fiberglass
 I c clamped a cock pit rim to the deck and slightly crushed the fiberglass on the rim. How do I remove the white crush spot without removing all of the glass?
Why don’t you remove the glass and put in new?
I was hoping to find a way to just repair the white crushed spot without removing the glass. I guess I will have to unless someone has another solution.
