First time posting, although I did a quick search earlier today to address a question about my sheer clamps.
I'm building a Chesapeake Sport Tandem with my girlfriend as our first boat. Everything's gone well so far, only a half inch wider than the plans specify, and we haven't broken up yet.
My question was about end pours. In the manual it doesn't specify how long to make them. Does it matter how long or can I get by with only like a 3 inch pour?
Not sure that my plans had a specific length, but I dammed my bow slightly after the low part of the seam, that ensured that the entire bow structure would be solid. I used a similar measure on the aft end.
Another consideration I used was where my bottom seams were... I had about 2" of wood beyond a scarf seam and I ensured my pour covered those for extra strength.
Good luck; hopefully someone with more expertise will weigh in,
Joe, first check your plans. My main objective was just to make sure there was enough good "meat" to drill the toggle handle holes through, and my CH 17LT plans don't show much more than that.
It sounds like some people like substantial end pours to make them super durable. But I figure if I hit something really hard, a boat this light will get damaged. If I had a giant end pour, the damage would probably just get transferred further aft in the boat. So I think of my somewhat fragile bow like the "crumple zone" of an car body. It will dissipate the energy of a collision so damage to the rest of the boat is reduced. Or doesn't that make any sense? :-)
Thanks for y'all's advice. I ended up doing the pours last night around midnight. I have a very strict time restriction so I just did the pours all at once.
Paul it happened just like you predicted. Smoke and bubbles and lots and lots of heat. However this morning it looked like both pours had cured well and I just finished putting on the deck.
I forgot to mention. The bow pour ended up being about 4 inches long, the stern pour a little less. But both of them really filled up that area that’s hard to reach when filleting so I think it’ll work.
Another option for the more weight conscious is to carve a block of wood to the approximate shape and then bed it in thickened epoxy.I did that for my WD12.Got the idea from Lazslo.Since I am going with a pad-eye top mounted handle, I went the route of back plating that is wide enough to the be filleted to the hull.A definite advantage of the extra beam http://morocz.com/BoatBuilding/DuckBuild3.htm
