My initial dry fit of the lower portion of the cockpit rim didn’t go very well and I’m looking for assistance. I laid out both the lower and the upper on a flat concrete floor (separately and away from the deck) and glued the puzzle joints, achieving a very good result.
A day later, I placed the lower coaming on the deck and had difficulty determining if there is a proper orientation as to forward or aft facing. The assembled rim did not easily line up with the deck’s cockpit cutout.
I clamped the forward end of the rim to the to the deck’s center line and while attempting to bend the coaming into position (to match the cockpit’s cut out), it cracked, not along the glue line, but cleanly across the grain. It will be an easy fix.
This the first and only time that the kit’s precut parts have let me down. Everything else has been superb.
So, before another dry fit or glueing attempt, a few questions. 1) is there indeed a forward and aft orientation that I need to concern myself with? 2) should I glue both the lower and upper coamings together before dry fitting and final glueing? 3)do the comings “mirror one another and should they perfectly line up with the edge of the cockpit opening or will I need to plan on some trimming/sanding?
Thanks in advance for any assistance. John
