GRAPHITE USAGE IDEAS
I am finishing a lot of parts on my Passagemaker take apart.
Need some input on using the graphite with epoxy. ( not sure if I should)
Inside daggerboard housing?, I will be painting my daggerboard white.
Drill and fill for thru bolts on rudder head. Do you think I can mix and fill a hole then drill with the idea of UV protection and less wear on the epoxy by bolt threads. I may be paiting my rudder white.
Masthead hole, boom and yard holes? I will only be varnishing the rest of the pieces.
Anthony
Definitely inside of daggerboard case.  I also painted my daggerboard and rudder w/graphite.  I wouldn't worry about lashing holes.  I used a small block instead of a hole at the masthead.  You could embed a metal sleeve if you're worried about the threads wearing or maybe epoxy putty on the threads that aren't needed.  Do you have a build blog?
