Although I had drilled some extra holes to confirm where the virtual spaces were in the double bulkheads of our sport sectional, we ended up sawing into one of them a bit. The only fix I could think of was to fill in some of the missing wood using epoxy. I built a temporary form to match the shape of the area, lined it with plastic (of course today was the today that my 3M adhesive spray stopped working), and taped it to the section. We then mixed up some epoxy with wood flower and worked it into the gap between the form and the bulkhead. It’s still curing so won’t know till later how it came out. I’ve used this approach before with specialized “architectural” epoxy that is easy to work with using hand planes, to repair exterior trim. Keeping fingers crossed that this will work. Pics below, 2 before applying epoxy, 2 after.
Update: I think the fix ended up working out well. My goal was to make sure that I had a flat surface for mating the two sections, and also to maintain a consistent gap once the sections were together, both of which turned out to be the case. Pics below. The one with the two sections together is after sanding and is with the rubber gasket in between.
I imagine I’m not the first person to saw into the bulkhead and probably won’t be the last so hoping this proves useful to others should the need arise.
-Rob
Nicely done ! Smart fix ![]()
