How much space is needed to build a passagemaker?
I would like to build a passagemaker dingy and I am curious as to how much space I will need to work without too many inconveniences? Can someone who has built one advise me? Would a 10x20 foot space be sufficient?
   The open floor space in my workshop is about 10x16, and I had enough room to build mine.   It can get a bit tight trying to bend down near the table saw or work bench, but if you're careful, that's enough space.
  Check out the Passagemaker forum.  There is a lot of excellent construction information that goes beyond the manual and comes from actual experiences of other PMD builders.
http://www.pmdbuilders.net/viewforum.php?f=2
  Jim
Thanks for your info about the passagemaker forum and info.
Paul
