How to remove blobs of epoxy?
Noob here. Gluing on the doublers on my second bulkhead I guess I got distracted and didn't scrape of the outflow after clamping. This is on the bottoms of the bulkheads (NE Dory) so maybe it won't be visible? I do care about weight though. Please see the picture. It's a like a 3mm bead of rockhard goop. I'd like advice on the best way to get this stuff off without damaging the plywood.
PS: is it normal that this commenting interface doesn't show a preview of an image? Anyway in case it didn't work here's the URL: http://imgur.com/f1tDkVt.
The internets says acetone, methylene chloride, heat gun, sharp scraper, angle grinder. I do own a Bosch "Dremel". No angle grinder though. Also, I'm posting pics of my build at an album in imgur: http://imgur.com/a/vHeEY.
   I have found for me a heat  gun and sharp furniture scraper works very well.
Don't forget the old fashioned razor knife, if it is still green. Best to wipe up quickly, but if it is a few hours old, will still take a nail print, any sharp instrament will work. Good luck. JRC.
   Definitely heat gun and a scraper to remove unwanted epoxy.  The heat gun is also useful for pulling out wires.  A little heat will soften the epoxy and allow the wire to be extracted with a needle nose or pliers.
   I nice hack I learned on this forum is to use an ordinary hair drier instead of a heat gun.
   Try a StewMac  Ultimate Scaper
https://www.stewmac.com/luthier-tools-and-supplies/types-of-tools/scrapers/stewmac-ultimate-scraper.html
It is easy to maintain the edge, and when done, this thing makes a great "epoxy erasure" for drips, runs, blobs, etc  Also great for smoothing the inevitable orange peel that epoxy forms
