Well, got the hull tack welded today. On the 14 with the angle in the tailblock, the only way to get epoxy in the joints seemed to be with a narrow stick. There are several places along the hull where I had a fair bit of daylight between panels. The sides look fair, no hard spots, and I was reluctant to clamp or otherwise pull them tight together. On the skerry, this was not a problem. Between fillets and fairing, it was all good. Hopefully SUP will do likewise.
Related topics
Topic | Replies | Views | Activity | |
Tack Weld on Kaholo? | 7 | 1 | March 14, 2013 | |
All wired up/tack welding question | 4 | 5 | January 13, 2014 | |
Kaholo 14 – Cyanoacrylate vs epoxy "tack weld"? | 6 | 1 | April 18, 2022 | |
Dory tack welds | 3 | 4 | December 22, 2013 | |
Jimmy Skiff - first time builder | 15 | 2 | November 9, 2020 |
