am waiting for the glue on the last set of planks to dry so i thought i would share the latest project I am working on and my continued exploration of light, performance sea kayaks optimized for where and how I like to paddle – creeks and rivers, generally flat to light chop and typically at a 65% pace with an occasional sprint to get the ticker going.
I have been operating under the thesis that if you make it easy to paddle, you paddle more. And I continue to affirm that a shorter lighter boat is often the way to go as speed is optimized once you know the input (power). So longer is not necessarily faster. At a relaxed paddle pace, the shorter boat may be actually faster than a longer boat due to the trade off between form drag (how much water you displacing and rate) vs surface drag (the number of square feet in the water of skin and its effect)
The last boat in this experiment I built, was a modified petrel play that came in at 28 lbs. It’s a tad under 14 feet loa and it’s been a real joy to paddle and easily gets the most use because it is simply easy to move around. The boat was built with 3/16 paulownia throughout. However, there were two disappointments with the boat. First, it was supposed to come in at 25 lbs but after construction, I was concerned that the bottom flat sections were too flexible (not stiff enough)….so I added another layer of glass on the bottom to stiffen it up. And glass and resin are heavy. I also miscalculated the weights of fittings and their impact. So while still very easy to manage….a bit of a let down on the weight. The second disappointment was how quickly the short hull runs out of top speed if you want to really lean into it. The boat is totally fine at 65% and easily keeps up with longer boats during a relaxed paddle, but you quickly feel it getting caught up in its own wave form if you push it.
My other experiment in light builds is a standard petrel with very close attention to detail in its build. On that boat I used 3/16 cedar and it came in at about 31 lbs and is definitely one of my favorite hulls in terms of handling and a reasonable turn in speed.
So the project this year is a modified version of a microbootlegger sport which has a hull very similar to the petrel with respect to LWL but about 1.5 feet shorter with a 15.5 LOA as it avoids the overhangs.
The target is 25 lbs and I hope to achieve this through minimizing rigging and using a core design of ¼ inch paulownia in the flat sections of the bottom of the hull (so I do not have to add glass for stiffness) and 3/16 paulownia for the rest of the boat and by reducing the total square footage of hull (to about 44 square feet) by taking 1.5 inches off of the shear line which on this boat is straight pretty much vertical. there are other cockpit modifications to use approaches i find convenient and easy like making the cockpit coaming proud and not flush which is sometimes tough on the fingers to get a skirt on.
All the paulownia was delivered in January and I am working now on the bottom of the hull.
Picture of the boat is below with the basic idea of what its cross section should look like with some of the comparison numbers vs the petrel play and petrel. SC 15.5 stands for spa creek in annapolis which is my home paddling creek and 15.5 is the loa.
The following picture is the hull under construction and you can see some of the thicker paulownia coming into play after the turn in the bilge.
the only other comment worth noting is paulownia is a lot cheaper than cedar and very easy to work with.
Don’t think I am working fast enough to get it done by big little boat festival…..but should be in the water later in the season with any luck.
hope this was interesting.
that said, definitely expect to be complete before next BLBF :)
