Non-UV exposed areas, what to do?
First time builder, varnisher, painter, and I’m building the Tenderly Dinghy.
I’m planning on varnishing all the UV-exposed interior surfaces. (Currently, everything is epoxy-coated.)
For any non-UV exposed areas, that will be difficult to see, it crossed my mind to paint with a light color: such as under the seats where the floats are fixed, under the floorboards, maybe the bilge-area (internal hull panels) under the floorboards, and maybe under the breast hook.
This seems more practical to do, but I wanted to ask the board what downside there is to painting these non-UV exposed areas, as opposed to varnishing them, or something else. Thanks!
As a rule I’ve treated every area as if it will get UV exposure. My flotation chambers for example have white primer in them. Even a perfectly dark space might get a little that you would not expect to be there.
Paint vs. varnish is purely an esthetic choice. Both provide UV protection. Use whichever you think looks better on your boat. It’s your boat, you get to pick. Either way it will be protected from UV.
A Tenderly is a great choice for a first build, and a light paint under the seats and floorboards will make the bilge much easier to check on later. Hope the varnish goes on smoothly.
