Did a skim coat of the hull. Skim coat of the deck went fine. After finishing the hull I noticed some light spots that does not seem to absorb the epoxy. I had sanded to 120# and initially used a tach cloth, but read that was wrong, so used Acetone to clean the hull.
Since it’s just a skim coat, I can sand the affected area then re-apply the epoxy, but want to make certain it’s a surface defect. All I can think of his glue squeeze out, but I did not see anything like that when sanding. One of the defects is in the middle of strip which would lead me away from the glue idea.
Thoughts?
Lou
I had something like this happen and it was packing tape and packing tape residue. I glassed over it before I noticed so I ended up cutting out some fiberglass to fix it. If you get it to bare wood it shouldn’t be an issue.
Its wood glue squeeze out and a hidden benefit of a skim coat (allowing you to see it)
Sand it out and confirm all off with another skim coat. With strip builds, the strips can be sanded without woŕying about sanding through a veneer…you should have space.
I would use 80 to 100 grit to get it off and then come over it with whatever finishing grit you used for rest of surface.
Sometimes with the right lighting you can notice it before the skim coat…but the skim coat reveals all…
H
As Howard says, it looks like thin pva glue. Wetting the wood with plan old tap water also works to show up the glue, showing a white patch and cheaper and quicker than a skim coat
Ditto to peter…water works too…just don’t go crazy with it
Thanks for the good suggestions! Going at it initially with 80# really helped.
I’m in the middle of fiberglassing. Just need to do fill coat in a couple of hours. Planning to do what Nick did with the Petral play where he did a light fill with the first layer, then put on another layer when hull and deck are joined to go between the chines and over the external stems.
in Nick’s book he suggest leaving the hull curing for multiple days before popping it off the forms. In his petal play video (possibly because it’s a light fill) he just did it overnight. If possible, I’d like to pop it off tomorrow so I can do the deck before it starts getting cold again. I can then work on the combing while it’s cold outside.
Is it possible to pop the hull of that fast or am I asking for trouble?
Lou
Whenever its anticipated off the forms for more than a work session, its a best practice to use tape to hold the width of the piece constant at the plan width or even slightly narrower. (Note: use high quality tape so you dont create a residue problem).
I say a ‘work session’ becuase you don’t want to be in a situation where something came up and now your temporary off becomes a week or more…and now it is really out of shape. (school of hard knocks…story for later)
It will naturally want to widen when not braced.
The picture below is what i do when i have a piece like this off the form.
Even if totally cured it will tend to widen. So my experience is to hold it in shape whenever off the forms to minimize the wrestling match when you need to mate the bottom to the top.
Howard,
If I support the hull to insure it does not widen, would 24 hrs be ok for cure time for the epoxy to pop it off the forms?
When I took the deck off the forms, I just got a 1 by piece of wood, and cut grooves at the widest point of the kayak (23"). I then dropped the hull onto those grooves, insuring the widest point was 23". Everything looked pretty stable. I guess I could do the same at the 4 1/2 and 13 1/2 foot point, or use your tape idea when I move the hull.
Lou
24 hours is fine as long as it has had a normal cure. Not tacky, cured
