Passagemaker Dinghy
I will be atttending the class at the end of March to build the Passagemaker and had a thought about a modification to it once I got it home. My main use of it will be sailing and maybe a trolling motor on it, not so much into rowing. I was thinking about lowering the aft seat, adding more support and extending it forward for more surface area. This way I could have a large surface area for sitting while sailing instead of sitting on the actual floor of the boat.
People's thoughts?
Sounds like a lot of trouble.  I built some "portable" side seats for our Passagemaker which have worked out well.  See my earlier post on that here:
https://www.clcboats.com/forum/clcforum/thread/44040.html
...and a link to a Dropbox folder with the photos, in case the one in that message doesn't work:
https://www.dropbox.com/sh/z2bmcxkorovln3k/AABWkWDoMrEcAn0nSsyDQFExa?dl=0
We use a trolling motor sometimes, and these seats work for that as well if one is solo.  What I don't do is take the motor and the sail rig both along on the same outing.  If the wind dies, I row, which is quite pleasant in this wonderfully versatile little dinghy.
Sing out if you have any questions.
   Thanks for reposting it, I am not sure those seats would hold me without some beefing up. :)
I will definately keep those in the back of my head.
Dean
