Hello All!
I wanted to share with the community my experiences of putting together the synthetic rig for my Passagemaker Dinghy (PMD). The standing rigging is all made of Amsteel Blue, a material very similar to Dyneema which is stronger than steel of the same diameter but with very similar stretching characteristics.
Firstly, I need to head off this post with a few disclaimers- what we are talking about in this post is the rigging. My PMD was built from plans and not a kit. I decided to use Douglas Fir marine ply and not Okoume. I have zero regret with that decision. Halfway through my build I ended up selling my house that had a lovely two- car garage workshop and at the time I wasn’t sure I would have the chance to finish the boat at all. Consequently, things were rushed. The beautiful low radius fillets that held the bulk heads and seats for the initial build were hastily slopped over with 3/8” beads and not cleaned up well. The bow seat was not cut correctly, and the front transom is a few degrees off square. In the words of my generation- YOLO.
If you think it takes a fragile man to issue a disclaimer so that his boat-building peers don’t criticize him on the internet, you’d be right. Please, please, please don’t tell me my fillets are sloppy, don’t share your negative thoughts on the boat’s finish, and for the love of god don’t nitpick the endearingly rough condition of some of the lumber cuts. I am well aware of the aesthetic quality issues. But I use this boat A LOT! I wanted a boat that I wasn’t going to be afraid to beat up a bit and after a full year of use and abuse she is holding her own. She is ugly AND I love her.
That said, it’s open season on the rigging, please let me know your thoughts. Also if you folks want to see how a gunter rig on the PMD is REALLY done, check out CaptainSkully’s Passagmaker rigging posts. He did some amazing things and I would say if you want to commit to having an exclusive sailing dinghy that would definitely be the way to go.
My approach is a bit different in that I am using the stock sliding gunter mast from CLC. I really like the ability to completely remove the rigging and only use the boat for rowing and trolling, which I do frequently. That said let’s get into it-
Photos are here- https://photos.app.goo.gl/zNdmfsL117FSrUmG7
Sorry they are in a weird order
Mast Step- I modified the mast step because I didn’t like how the original through-hole style damages seat. I tried to pad the hole with felt but it still was doing a number on the wood. I ended up talking a 3/8” through hole piece and then gluing that on top of identical 1/4” piece but without the hole. I needed the mast to sit a bit deeper so I added a smaller 1/4” piece for the top that adds a bit of girth to the assembly.
Stays- I used Samson Ropes’ 7/64” Amsteel Blue product. Amsteel Blue is the name of the material and comes in several colors and I went with red because I wanted it to complement my Douglas Fowler made tanbark sails. The rope is available from Amazon and I believe and 100’ was around $50ish dollars.
One does not simply make knots with Amsteel so you are going to need to do legit eye splices at each end. Because of the small diameter of the of the rope it is recommended to use Brummel Locks rather than the weaving required in a Class I eye splice. I also crudely stitched some flat webbing around the masthead side of the stays and then added thimbles to the lower ends that clip into the snap shackles.
I’m intentionally not giving lengths for the stays because I’m not convinced my lengths would be right for a kit-built PMD. Also when you make up your shrouds add a few inches BETWEEN the Brummel locks because the overall length will contract when you bury the tag ends. As a rule your tag ends should be around 18” for this diameter. It is for this reason I have 2” paracord loops that run through my thimbles in the pictures.
Soft Shackles-Soft shackles are the cat’s @$$h- errr- meow! They are seriously awesome. I highly recommend this video from HowNotToHighline on how to make them up with the Brion Toss button knot. I also strongly recommend you practice with 110 paracord and make several before you attempt on the Amsteel.
https://www.youtube.com/watch?v=91_jEjQdlBU – NOTE: This video was made by rock-climbers who don’t use the same sort of discretion with their vocabularies as us honorable sailor types so be advised there may be some mildly offensive commentary including a brief reference to an inappropriate act with a Smurf. I do think it is the best video out there, though. Be sure to check out the channel for some other insightful uses of softshackles.
Poor-man’s Turnbuckles- In order to properly tension the rig I do use some less-than-marine-rated turnbuckles which are quick-linked on the ends one of which has a snap shackle. This would definitely be the weak link on the system and that’s why I use short slings to serve as a back-up if these failed.
Slings- I use slings, which are short lengths (about 14”) with Brummel Locks on each end as “back-ups” that overlay the turnbuckle and snap-shackle tensioning device.
Mast Head- I attach the forstay to the mast cap in a girth-hitch like fashion. I have found that this does not interfere with the mainsail halyard that also uses the hole in the mast cap. Under that is the first eyestrap that captures the loops of the shrouds- notice my novel abraision-reducing/anti-rotation webbing and zip-tie solution. Under that is a dedicated eyestrap and block for the jib-halyard. This because I really don’t like the “set-flying” nature of the jib. I have posted about this in the past if you care to understand my reasoning.
Rigging Process- I pass a softshackle through a hole in forward bulkhead knee (make sure this hole is sanded smooth and won’t catch threads of the shackle) and loop it through BOTH the sling AND the lower quicklink in the turnbuckle assembly. With the turnbuckle at its full length, I pre-attach the assembly to the shroud thimbles before stepping the mast while the mast is still laying horizontal. I have found that the shrouds can be somewhat loose and still allow the mast to be stepped. I then step the mast and somewhat tighten the turnbuckle of the side of the boat I am standing on. Then, I grab the forstay and use a long softshackle to attach it to the front handle in the transom. At this point, the rig is loose but it won’t be able to come down. I then tension the turnbuckles on the shrouds before establishing the final tension of the forstay that gives the mast the correct 4 1/2" rake.
PRO tip- Don’t worry about attaching the backups until the rig is tensioned fully. Also I use back-ups around my tensioning system only because I used dubious quality turnbuckles and snapshackles. If you invested in appropriately rated components this could definitely be omitted. As John Harris explains in the manual, marine turnbuckles are stupidly expensive.
Please let me know your thoughts and happy building to all!
-Pat
FIN
