Well I don't know what happened there! Trying to see if I can post a pic from Dropbox
"https://www.dropbox.com/home?preview=20170319_081357.jpg"
Mike,
Unfortunately, when your photo link is followed it returns an error "Please sign in or register to access this page."
You need to be able to use a URL that doesn't require authentication.
Regards,
Dick
How does one embed an image directly in the message? Not a link. I'm trying this:
Can anyone please give me a clue?
Mike when I follow the link you posted I get a dropbox login request, so I presume you have not given the permissions to your photo so that it's in the public domain. I have done with imgur, above, as far as I know.
1. Upload your photo to tinypic.com
2. Copy Direct link for layouts
3. Click on Image icon on the post page
4. Paste in the URL
5. Click in the widrh box and enter an appropriate number (350)
Your done!
Mike,
That link works! You should be able to use it.
Regards,
Dick
That won't work, either. It only brings up a lo-res thumbnail if you paste it into a CLC image dialog.
The problem is that dropbox generates the webpage via javascript, so even using a link that ends in .jpg doesn't produce a direct link to the image. Instead, it creates an image viewer webpage which doesn't play nice with anything that wants only a direct link.
You need to go to the page, right-click on the image and copy the image location. Even so, on some systems the picture may not show up until it's viewed directly and thus put into the browser's image cache.
The web developers are getting too tricky.
Thanks. I was missing two things:
"The hedgehog":
hat's the 2nd post I made that did not save...? Not sure what I am doing wrong, lets see if this works. I am trying the Tinypic suggestion.
The Tinypic site does seem to work, but it too has issues. Or maybe its just me that has issues. Tinypic seems to rotate everything to a horizontal framing. It does not seem to have a rotate feature. There has to be a better way.
Here's my revised recipe Mike:
Hope this helps, John
PS: I made my album public in imgur and it seems to have attracted quite a view views, along with comments like "You're gonna need to start over, it doesn't look anything like Ellen Degeneres". and "You are gonna need a bigger boat." (Jaws meme).
Nobody's mentioned that handy link right on the front page of the list of posts. It's called Click here for help on including photos in your forum posts.
Just saying :-)
