PMD - daggerboard trunk fit
After a medical hiatus I have returned to continue with my PMD build.  I find that the daggerboard trunk is not fitting flush against either the vertical or botttom surface of the center bulkhead.  At one point the fit was too tight so I obviously over-corrected.  There is perhaps up to an 1/8 in clearance on both surfaces.  Can I simply fill in with thickened epoxy?  I have thought about trying to use shims but wasnt able to fit anythig in .that made sense,  Suggestions are appreciated.  I would attach photos but have uneven success doing so.  Bruce
