So, because I opted for the wooden mast, I've got a fixed gooseneck on the boom. The Sailrite kit I ordered didn't seem to have an option for reef points built into the sail. I figure I could do it if I needed to, but first, I wanted to discuss the logistics.
If the boom is fixed and the mainsail is loose-footed, then reefing the main would entail the yard being farther away from the block at the top of the mast, although its constrained by the sail track and sliding gooseneck.
I can always dump wind with mainsail trim, but it might be nice to have a set of reef points ready to engage if needed. I found an old thread from 2010 where it had begun to be discussed, but no actual findings.
I have plenty of grommets left over from the build and scrap Dacron, so in about an hour, I could install reef points if I knew where to place them. For that, I'll ask Sailrite, but I thought I'd ask about the feasibility first here.
Any thoughts?
