Pocket ship new guy
I’ve earned Basic level already! Sounds about right. I recently ordered a Pocket Ship kit. Before I ask any questions, let me introduce myself.
I’m a retired firefighter living in coastal southern CA. I’ve not sailed much since my youth, but I’ve built a handful of canoes and kayaks, and also a Waters 17 trimaran (which is on this website). I’m fairly familiar with basic woodworking and glassing, but have never done stitch and glue. I am afflicted with a need to tinker with things that already work fine. I have a dislike for sanding, though in my teens I worked as an Abrasion Technologist.
First question: What about increasing sail area by 10% maybe, by lengthening mast 12” or so and enlarging sails in same proportions? Where I live, the winds are light, and squalls and thunderstorms etc. very rare. Also they mostly blow 10am to 5pm, so generally the beginning and end of any daysailing is just ‘ghosting’ along.
2nd question: Why not glass both sides as much as possible before assembly, and just tape it after the filleting? Glassing flat on garage floor is easy, crawling in bilges to glass and sand is harder.
Thanks for reading this, I look forward to chatting with you all. And if Mr. Harris should see this, thanks so much for designing a truly great boat!
Welcome to the club! The Pocketship is sweet little boat.
The Pocketship has a pretty generous sail area already. She will move along well in light breeze.
Too bad the Pocketship forum is down, as there is a thread there where John added a topsail. Pretty cool looking. If you google Pocketship Topsail you can find some pictures.
if you pre-epoxy panels they may be hard to bend into place -especially at the bow. I did pre-glass the cabin top as it is a fairly gentle bend.
To expand a bit on Steve’s reply:
TLDR:
  • You can pre-glass if the curve is gentle enough
  • You can test the curve for suitability for pre-glassing
  • Pre-glassed panels stitched before the epoxy fully cures will be more flexible
  • Panels glassed only on one side (typically inside) will be more flexible
  • If this is to avoid sanding in confined spaces, there’s other ways than pre-glassing:
    1. Pre-saturate the glass
    2. Blot the glass
    3. Use many thin coats instead of several thick ones
    4. Fill the weave with epoxy/phenolic microballoon mix instead of unthickened epoxy when painting
  • Deviate from the manual at your own risk
If the curve is gentle enough, glassing before assembly is no problem. The trick is figuring out if it’s gentle enough. One way to do this is to actually bend the wood to the final shape and see how much effort it takes. Since Steve was able to pre-glass the cabin top, that’s a known calibration point. If the bare wood takes the same or less effort to bend than the cabin top, it’s a candidate for pre-glassing.
Looking at the construction gallery, it looks as if the bow section, just as Steve mentioned is the real trouble spot, but the rest looks as if it’ll probably be OK to pre-glass.
You can also work a little differently to accommodate pre-glassing. For one thing, epoxy takes a while to fully cure. Depending on the temperatures in your work area, it could take days to weeks before it’s fully cured. In most cases, for the first 2 or three days it’s got reasonable flexibility. So you could glass a piece while it’s flat, then as soon as it’s cured to where it’s no longer tacky to the touch, bend it into place and stitch it.
Be aware that doing this requires more thought and preparation (and some skill) than the sequence in the manual. It will not necessarily save you calendar and clock time; it may take more. It just changes the kind of work that you have to do. It also puts some serious timing constraints on the assembly process. You have to stitch panels into place when they’re ready, not when you’re ready.
Another possibility is to pre-glass only the interiors. Access to the exterior sides of the pieces is pretty good throughout the build, it’s only the interior that needs contortions. Leaving the exterior unglassed while pre-glassing the inside helps reduce the bending/stiffness problems. With no glass on the outside, there’s no additional tension to resist bending from the outside. The inside is being compressed, which uncured glass/epoxy can’t resist as strongly as tension.
So pre-glassing is manageable, but keep in mind that it is more complex and has a higher chance of something going wrong than the sequence in the manual. Anyone deviating from the manual should have enough experience to know what they’re doing.
But, if your main goal is avoiding sanding, that’s a lot easier to do. First, keep in mind that most of the difficult interior surfaces will be invisible, covered by the cockpit and cabin soles. Personally, in those cases I see no reason to sand them, or to even fill the weave or paint them.
Second, the main reason to sand is to remove the globs and drips caused by applying too much epoxy. That can be handled without sanding in at least three ways - pre-saturate the glass outside the boat, apply many thin coats instead of several thick ones and use paper towels to blot the excess.
Pre-saturation is done on a large table covered in polyethylene sheeting. Spread out the glass, mix up the epoxy and wet the glass out. Spread the epoxy thoroughly and evenly, using only enough to thoroughly saturate the glass. Roll the glass up, move it into the boat onto the desired surface and unroll it, smoothing it into place with a gloved hand. This is an extremely messy process needing a significantly larger space for the table and possibly a helper. When mastered, though, it gives you a nearly perfect wetting out with little or no sanding. Again, it only changes the type of work you’re doing, not eliminating any.
The paper towel method is one that I adapted from a model airplane builder who posted here some 20 years or so ago. He (I’ve lost the name so I can’t give him full credit) suggested using toilet paper as a blotter. Once you’ve wet out the glass, just unroll the paper over the glass, let is sit for 60 seconds or so while it blots up the excess (you’ll see it change color as it does this) and then remove and discard the paper. I changed the method to use paper towels, to gently pat them into place and then, once they’re removed, to tip the surface with a dry foam brush to remove bubbles and any imprint if the paper had an embossed pattern. The result is an essentially perfect matte surface that needs no sanding at all, ready for the weave to be filled. This is similar to the result you get with Peel-Ply, except a lot cheaper and without the compound bending problems. The downside is the enormous amount of trash that this method generates. As long as you let the soaked paper towels fully cure, they won’t be hazardous waste, but there will be a lot. On the other hand there won’t be clouds of microplastic dust, sanding disks, noise and it uses no electricity.
Lots of thin coats instead of several thick ones works because epoxy that isn’t there can’t drip. It does take more time, though.
Another way to avoid sanding effort is to fill the weave with epoxy/phenolic microballoon mix under paint, rather than with unthickened epoxy. The mix is much easier to sand. Because of the color it can’t be used under varnished finishes.
So this post has gone on long enough, hope it helps,
Laszlo, Thanks for taking the time to write this. Lots of good advice and a couple of neat tricks. I especially relate to the idea of expending minimum effort on finishes that are below decks. As my old concrete finisher friend used to say “It’s fine; I can’t see it from my house”.
-Rich
Thanks Steve! Yes, I’ve seen a pic of that topsail. Very strong Master and Commander vibe. Looking closer at build pics confirms what you say…that nose end needs to be raw wood to make the bend.
Just checking in to say; I did a thing. I’m hoping it’s less annoying to comment on my old thread than start a new one.
I got my kit and it is great. I also bought some dimensional lumber (Sitka) in dimensions I didn’t know existed. 8/4 x 12” x 16’. $400 a piece at the wood boutique. Frickin’ timber! which I had an amateur millwright reduce to exact dimensions for all the spars. $250 well spent. So I got the keel done and the little spars laminated. Only hassle is the yard warped a little when I cut it down to final shape. Probably gonna coax it back w a very little Kevlar roving epoxied on the “long” side. Lead part was easier than I thought. The shot I bought was maybe 1/16” so it melted really fast. 15lbs in a kettle for 10min and it poured like water. Not much smoke, but I took all the regular precautions. I kept stirring the (minimal) dross back into each batch, right before pouring. This was not a good idea. Right as I finished the last pour things got very lumpy, and the kettle clogged up. Here’s some pics
Rich
Looks a great start! It’s a journey, but I kept thinking in small stages: “that page is done, I won’t need to that part again”.
Good lumber is expensive, but it will be a joy to work with.
I think it’s good to stay in one thread for updates. We will come to recognize the title. It’s a shame they seem to having so much trouble getting the Pocketship forum back up. It’s a great group of people with excellent advice.
I really like this boat. It’s easily single-handed (though I’ve had some learning experiences!) and has a good, stable feel. I did not hesitate taking it out last week on the cold Potomac in 50 degree weather.
