Any advice out there for installing rubrails on a ch17?... currently have rails cut, and have not installed deck yet ... i'm thinking of attaching deck, cutting and planing flush - then installing rails before glassing deck - bringing glass over the rails - and cutting off below rail ...deck will be bright, hull painted.
Any better ways?
BP
I have rubrails on my 17 LT. Lessons learned:
- Don't put rails on until the deck is on and deck edges trimmed.
- As you sand the edge where the deck meets the hull, so so carefully in order to retain the "fair curve".
- Don't lay either the deck or the hull fiberglass over the rails. Doing so will ensure that you will NEVER be able to remove them!
- Put one coat of epoxy on rails before installation to seal wood.
- I used thickened epoxy, along with brass tacks, to secure the rails.
- When installing the rails, get a helper! I installed mine solo and can see spots where the vertical alignment is off.
- When varnishing, I would varnish the rails as a separate step from doing the hull and the deck (avoids drips)
- Whether when varnishing the deck or the hull, tape off the rails to prevent drips.
I hope this helps!
Tim Clark
