After an interruption of construction on a Chesapeake 17LT, I am finally able to resume construction.
To date, I have basically completed the hull. The next step of construction is the building of the deck. But, my understanding is that I could also start sanding the hull prior to doing the deck.
So my question is...which would make the most sense to do next - start building the decking or start sanding the hull?
Thanks in advance!
