Just put on my first coat of varnish and can says 12 hr recoat time. My question is do I need to wait to sand also or can I sand it sooner? Also I keep seeing the recommendation for the green scotch brute pads to sand. I found 3m synthetic steel wool. 0 fine coarseness. Is that the correct stuff? Thanks.
Related topics
Topic | Replies | Views | Activity | |
Sanding varnish | 7 | 1 | September 29, 2022 | |
Lenght of time between coats of varnish | 1 | 1 | May 21, 2008 | |
Schooner varnish re-coat time? | 1 | 6 | April 27, 2010 | |
Scuffing hull between last 3 varnish coats. | 3 | 1 | June 23, 2018 | |
Wet sanding varnishing prior to the final coat | 5 | 14 | November 2, 2022 |
