Sawhorses level?
I am building a Cheasapeake 16lt. I have 2 sawhorses I built on plans by Bob Emser and a set plastic Dewalt. I have only seen one mention on this forum that saw horses need to be level. Do they? How level? Reasonably so? Sorry for so many questions.
It is not imperative that your saw horses are perfectly level. If you look at page 78-79 of the build manual it steps you through the process of hull leveling.
To Mark’s point, the important part is that the hull is “true”. level sawhorses don’t guarantee this…but are helpful…so i always level them as a matter of course.
you want to ensure:
  1. from front to back the keel line and bow and stern line are straight
  2. the hull shape is symetrical relative to the plane that splits the the boat’s right/left halves and aligns with bulkhead shape at key reference points.
  3. no twist
  4. when viewed from the side, the hull lines are per plan
the stitch and glue kits, which are computer cut, will almost always pop right into shape with the biggest risk, based on my experience, is having twist and from front to back, not having a straight like along the keep and bow and stern (where the boat basically is stitched together all along the middle)
so this is one step, in my view that is worth the extra time to get it as good as you can get it.
helpful in this step is to read the techniques mark mentioned about twist, and potentially opening a garage door so you can really sight down that centerline properly. sometimes you need to let the hull hang or otherwise support it from the chines becuase if it sits on the sawhorse, pushing up on the keel, can distort the shape.
i am making it perhaps sound more complicated than it is…just trying to give the benefit of some of the mistakes i have made over the years :slight_smile:
Howard,
I did reasonably level the sawhorses when I built the work table so I had a flat surface. I do know about the boat leveling “winding” process as in the manual and video. I was just wondering about leveling the saw horses to start with before I get the “winding” process. I may just use the Dewalt sawhorses when I check for twist. They are probably closer to level than the pair I built. I’ll check for level either way. Thanks.
Mark,
I know about the winding process to check for twist. I was just wondering about the sawhorses being level before I start that process. I might just use the factory built Dewalt pair instead of the pair I built. They are likely more level. I will check anyway. Thanks again.
Rob
