Do I rough up the surface of the fiberglassed Chesapeake 16Lt deck between coats of resin with scotchbrite pads? I think I did this for the hull. I plan on varnishing the deck and painting the hull. I honestly don’t remember if I did this for the hull between coats.
Between coats of what, varnish, epoxy …?
not really necessary between fill coats of epoxy if you are doing the fill coats within 24 to 48 hours of the previous coat.. otherwise a light scuffing is useful.
Looks really good
you did a nice job of glass to the sides.
Howard,
Thanks. I can just about see the end. I am just hoping I can paint and varnish before it gets too cold.
Rob
I worked like a man possessed all summer trying to be painted and varnished by fall. I almost made it. Well fall is here, now I figure I can slow down and enjoy the build a little more.
its nice to see your work and brings back memories. i built 4 clc 17lts over the years. here is an old picture of two of them plus my wife’s 14 which we still have to today ![]()
you now just need to pick your color…you are on the home stretch!
Howard,
They look great! I already picked a color, “Fighting Lady,” a light yellow Ezpoxy from Pettit.
Rob
Jon
That is good advice. Thanks.
Rob
That sounds great. One interesting thing i learned with my yellow boat was that it took a couple of extra coats compared to the darker colors to get a consistent solid color.
The key thing on paint application is clean subrate (no contaminants), thin coats, proper dry time between coats.
With the first thin coat of yellow you will still see through to the grain of the underlying wood. Don’t try a coat so heavy that it fully covers…it will be way too thick. If the darker colors got done in 3 thin coats, yellow took four or five coats to get the uniform color you see in the picture.
H
Howard,
Well a least I won’t have too much left over yellow paint sitting on a shelf. Thanks for the heads up.
Rob
