Approximately how much resin an hardener would I need for the shearwater sport 14 ft kayack.
According to the Materials list for plans builders page you need a MAS economy kit #2. That has 1.5 gallons of resin and .75 gallons of hardener.
just a note that clc epoxy recommendations for the boat are quite conservative....so if you are careful and don't waste epoxy....you will have plenty left.
similarly, if you are new to building and are not particularly efficient, you don't have to worry about running out of epoxy if you buy the recommended economy kit (#2).
after having built a number of the CLC kits and learning to be careful, i find it pretty easy to build using only ~ 60% of the expoxy that that is provided.
i hope that provides a bit more color on your question.
Yes I’m building my first. Thanks for the answer
