Stitching question
I'm building the eastport nesting pram from a kit. I have almost finished stitching the pieces together but i can't seem to get the seams to be tight at the stern. I've got about a quarter inch gap between the bottom and the first hull panels. Is this something that can be fixed in the filling and fiberglass stages? Or should I start over?
   Hello Travis,
This happened with my skerry, I loosened some of the stiches and then tightened them again after some jiggiling.
Question, have you put in any of the bulkheads? Once you have more structure the ends come to shape better as well.
Bests
T
