Thinning epoxy?
What do I use (i.e., alcohol), and would Bekols solvent work?
Also, what percentages?
Appreciate any info/insight, thanks,
Larry
As far as I know you can't thin epoxy.  The only choice is to use it in warmer conditions where it would be naturally thinner.
 Alcohol does a good job of cleaning up after epoxy - but I would be afraid that if you mixed it in - you would get a result that would either never set - or if it did set would not be strong or smooth.
Justin,
I've read somewhere that you can thin it (I think with about 10% alcohol but want to confirm that).  Strength isn't my goal, as I'm simply coating glass on my coaming... spreadability (is that a word?) is what I'm after.
Given your comments I'll hold off until I get more feedback;
Thanks,
Larry
The best thing to do would be to check on the epoxy manufacturer’s web site or else give them a call/e-mail since it could vary by brand.  I know from experience that both MAS and System 3 are very quick with e-mail responses.
You can increase the "spreadability" of epoxy by warming it (and the surface to which you are planning to apply it.).... putting a work light with an ordinary light bulb near the resin & hardener jugs for an hour or so (or putting the closed jugs in a bucket of hot water) will help significantly..... it's just like warming up a jar of honey or bottle of maple syrup...warm = runny...but when it's cold, it's as slow moving as......molasses.
Julie K.
System 3 Marine Epoxy can be thinned up to 10% by volume with lacquer thinner. System 3 Silvertip cannot be thinned.
Thinned epoxy should never be used for a structural purpose, such as glue.It should always be covered with a layer of unthinned epoxy to seal the holes left by evaporating thinner.
So the takeaway is - it's definitely possible with some brands for some applications, but with all the restrictions you'd be better off with using a short nap roller and a low-viscosity epoxy, such as Silvertip, to get thin layers.
Thanks everyone.  In the end I wound up going with it straight (MAS w-slow hardener).  It warmed up enough that I was able to get a good coat on and the result was very nice.  My very scratched up (i.e., sanded) carbon coaming came out shiney & smooth!  That's my favorite part of this boat.
Couple pics:
http://i42.tinypic.com/174aj9.jpg
http://i43.tinypic.com/1pgq6d.jpg
Larry
