I just got the SUT-200 trailer for the Skerry.
As I try to adjust the pads to the hull, it seems to me that if the blocks were a little shorter on the inside (particularly on the front, then they would fit the hull panels more cleanly as they could rotate a bit more steeply.
Anyone have any experience and advice for making adjustments to the positioning and alterations to the pads?
Pat
Greeeting Pat,
Just got my skerry on the trailer last weekend, I was able to ajust the bolsters with the boat on the trailer. I used a rolled up cargo blanket to support the boat next to the bolster I was ajusting. Moved the cradle into position then sungged things up. I found the bolsters needed to be in the outboard position on both of the support arms.
I also thought of triming the forward bolsters and drilling a second set of mounting points further out on the aft support arms, but after some ajusting I think it will be fine without the mods.
Patrick
Thanks Patrick,
Both of mine are also on the outside position of the support arms.
I will fiddle a bit more with it.
thanks,
Pat
