Got my kit and couldn’t wait. so I’ve started. hull and deck are tack welded. 2 questions, first which bulkhead on deck is the permanet one?(I assume the one right behind seat. second, can I leave the two bulkheads furhtest fore and aft of the kayak? if so how do youepoxy and tape the hull to deck from the inside? or can this be left not epoxied? so far very simple and straight forward. great project!
John
>>>>which bulkhead on deck is the permanet one?(I assume the one right behind seat.>>>
NONE of the temporary deck forms are permanent. Those will come out after the glue on the underside of the deck cures.
>>>can I leave the two bulkheads furhtest fore and aft of the kayak?>>
Only if you cut hatch openings in the deck so that you can reach in and fasten the deck to the hull. You can't go without that vital interior reinforcement.
