Attaching deck
Due to adding some 'art' which starts on the deck and runs over to the side hull, I would like to glass the hull after the deck is attached.  Any problems delaying the hull glassing?
 Kim
I can’t see any problem with it.  I think the main reason for glassing the hull first is to protect it from getting scraped up and stained during the rest of the building process.  I think a layer of fiberglass on the inside of the hull should be good enough to keep the hull as stiff as you would want it.
