hi david,
in summary, i like how she paddles
by way of background, i currently have in the inventory a petrel, a petrel play, and a night heron that all get a lot of use and during the season. i am usually out paddling 3 to 5 times a week. the microbootlegger, which i have only had for the 2025 season, probably has ~ 250 miles under its belt so far. i weigh about 186 lbs and am 5 10 with size 10.5 feet.
here are my notes about how this boat performs.
all the boats i routinely paddle all share a similar hull shape as part of the petrel, night heron series. rounded profiles front and back and a soft chine under the seat area. this is similar to a hull you would see in a romany/NDK explorer or wilderness systems tempest.
without the skeg down, very maneuverable and responds well to leaned turns. not too hard to make it go straight when you want that. but with a bit of skeg, she locks in and drives straight as an arrow with little to no corrective strokes required.
she is definitely capable of moving fast and if i take the pace up she responds well and does not suffer from the problem i had with the petrel play which just becomes captured in its own wave form. the sport, at 15.5 feet has almost all of that as waterline (lwl of 15.3 feet)…so by length waterline/speed potential she is significantly longer than the 13.1 lwl for the petrel play, slightly longer than 15 feet lwl for the petrel, and a tad shorter than the 16 feet lwl for the night heron but avoids the 18 foot package. i have a regular exercise paddle of 2.5 nautical miles that i routinely cover in about 40 minutes (works out to about 4.3 mph) with this boat.,…this is pushing harder than a leisurly paddle…, but not a sprint.
she has less rocker then the petrels…and more equivelent to the night heron. so while generally easy to spin around without skeg, a bit more effort then the petrels.
the bow does not have signficant flare given the destroyer design so she tends to stay level in small chop and cuts through it vs bouncing over it. when i catch a sharp boat wake, its good that i paddle with a skirt.
as discussed in the build blog…i built the boat for flatwater and took volume out of it above the waterline so this wave piercing tendency is going to be more than a standard microbootlegger. so i would be remiss to take the boat into bigger seas where i would be more comfortable in the petrel. that said, when its windy, there is not a lot of windage and i can handle high winds in flat water better than a boat with more volume. i have had her out in 20 knts breeze with stronger gusts and was able to keep her moving.
the boat has good primary and secondary stability…so she does not strike me as tippy…
the boat is narrower than the petrel play at only 22 inches max width so one other thing i have noticed is a lot less accidental paddle strikes on the deck. (the petrel play is 23 inches and the petrel and night heron are only 20 inches wide)
the boat is relatively roomy compared to a petrel and similar to the petrel play.
overall, a fun boat…and an interesting look. not a classic greenland design but i still get a lot of nice comments from passersby at the launch site and on the water.
