Starboard side spacer blocks are in the clamps. That is just about every spring clamp I own. The three blocks that were done separately are unusual sizes, all the rest are 2”. The middle one is cut special for the thole pins.
Fall has finally arrived in East Tennessee. Temps over night in the 40’s even 30’s. I have gallons of slow cure. I’m planning another big order to CLC in November. I’ll probably get a gallon of MAS Medium hardener then. Till then I’ll have to make do. I’m thinking about using heat pads, hot hands, and other such things to help the epoxy cure for small localized layups. Anybody have experience with this?
Outwales are in the clamps. I’m using two heat pads and a thermostat. I set it for 70F. The digital display looks fine in person but doesn’t show up on camera. Insulation is old towels and a tarp.
That’s caused by a multiplexed display. Try a lower ISO and longer exposure if you care.
Thanks Laszlo, next time I’ll play with the camera settings. Here you can see the heat pad, temperature probe, etc.
First thing in the morning the ambient temp is 38 but the warmers kept the epoxy at 54.3.
I set aside the two best boards for the outer outwales. The Inner outwale, starboard side is in the clamps. It went pretty good. I should have made my pilot holes bigger for the temporary screws at the breasthook. It split a little. I’ll repair the split after the epoxy sets up.
Prepping for cold weather boat building. Two hot tents combined end to end and a small wood stove should do most of the heavy lifting. It’s a little claustrophobic in there but at least it will be warm. I enclosed my old cooler in cardboard; the gallons of unopened epoxy inside are heated with a warming pad on a thermostat. They should act like thermal mass. The pumps are in the same enclosure on top of the cooler. The starboard inner outwale turned out great!
I sort of pulled slightly thickened epoxy into the cracked outwale board with a tiny zip tie. Think dental floss technique. A hurky C clamp with taped spacer blocks provides pressure. You always want to put the threaded part of the clamp above the epoxy if you can. The hot tent is okay so far. On nice days I can unhook a whole side and push it out of the way.
Port side inner layer outwale is in the clamps. I was careful to drill a slightly larger pilot hole and I put some washers on the screw at the breasthook. No split this time.
When I hear claustrophobic space and woodstove in the same sentence, I think carbon monoxide. A detector might be a good investment.
You might want to review epoxy amine blush recovery procedures. The MAS non-blushing product is very good, but it will blush if your temperatures should dip below the dew point. The fix involves washing the blush with water.
Laszlo,
You are right and it didn’t even occur to me, thank you. I’ve slept in one of these tents with this stove going for over a week once a few years back. Hot tents aren’t air tight or anything but I will get a Carbon Monoxide Detector, that is wisdom.
RHP,
I had a blush issue on the bottom of the boat earlier in the summer. MAS is excellent but if you push it outside its envelope, it let’s you know. When I think of how many gallons of MAS epoxy I’ve done and only one application where it blushed is extremely good. I’ve used various epoxy systems over the years and I am so impressed with MAS.
For both concerns a free standing Carbon Monoxide detector with thermometer would be nice. I see a lot that do Carbon Dioxide and temp/ humidity etc. But none that do Carbon Monoxide. So I’ll probably just get an Carbon Monoxide detector and an old school mercury thermometer.
I also have this 1500W Infrared heater in a wood cabinet. While it can’t compete with a wood stove, it makes a surprising amount of heat and is much safer. Thanks for the wisdom guys. I want to have my boat launched by spring, still much to do. Any other cold weather boat building tips are most welcome!
My improvised epoxy warming cabinet is working well. The ambient temperature outside this morning is 42 degrees. Surprising what an old cooler and a couple layers of cardboard and towels can do.
Motor well kit, Sailing Kit, and Trailex trailer on the way. Hopefully the Trailex arrives drama free.
@Gene_Stratton I ordered the taller mainmast. I also ordered a half gallon of MAS medium hardener, anybody used that yet? What can I expect?
I don’t want to flip the boat for sawing the motor well hole in the bottom. I’m going to try to cut it carefully from inside the foot well with a combination of my jig saw and a little bonsai saw.
Still working on outwales and inwales. My progress has slowed measurably. Lost my Grandfather, the old buzzard made it to 96.
Portside outwale is trimmed but not shaped yet. Starboard side outer layer outwale is in the clamps. This is the final piece of the basic Southwester Dory Kit. Whew! I deliberately left all the wale boards laying in the boat for many days, they tend to find a a natural curve from gravity that way. It made it a little easier to clamp a curved board to a curved boat.
