While stripping my Auk 17, I didn't want to use too little glue, so I used too much, and thinking I had to work quickly with the strips, I didn't wipe off the excess glue as I went. Only doing two or three rows a night on the hull, it didn't look too bad, and the next morning when it was dry, it looked even less bad. Not wiping it off was a huge!! mistake. I'm cleaning up the hull with a paint scraper, and a multi blade, multi sided glue scraper. Is there anything out there that is more effective??...when the right side was cleaned up, I started planing it. I had a little problem with grain....One strip would plane very nicely, but some adjoining strips the grain went the other way, and even with a sharp plane I got digs and gouges. Is there any way to avoid this?? or do I just do the best I can, and try to clean it up with sanding? Thankfully, I took more care on the deck and wiped off all the excess glue. TKS
